Design of Experiments Guide > Full Factorial Designs > Build a Full Factorial Design
Publication date: 11/29/2021
Build a Full Factorial design by selecting DOE > Classical > Full Factorial Design. First define your responses and factors. Next, continue to the output options. The design process follows the flow in Figure 12.7. For more information on work flow see The DOE Workflow: Describe, Specify, Design.
Figure 12.7 Full Factorial Design Flow
