Design of Experiments Guide > Accelerated Life Test Designs > Build an Accelerated Life Test Design
Publication date: 11/29/2021
Build an accelerated lift test (ALT) design by selecting DOE > Special Purpose > Accelerated Life Test Design. The Accelerated Life Test Plan is updated as you work through the design. The steps for building an accelerated life test design follow the flow in Figure 22.15.
Figure 22.15 Accelerated Life Test Plan Flow
This section describes the outlines in the Accelerated Life Test Plan flow.
