Publication date: 11/29/2021
Cause and Effect Diagram Menu Options
The Cause and Effect Diagram red triangle menu contains the following options:
See Redo Menus in Reports and Save Script Menus in Reports in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
