Publication date: 11/29/2021
Choice Design Window
The Choice Design window walks you through the steps to construct a choice design for modeling attribute preferences. You can specify an assumed model and prior information.
The Choice Design window updates as you work through the design steps. The outlines, separated by buttons that update the outlines, follow the flow in Figure 18.15.
Figure 18.15 Choice Design Flow
Choice Design Flow
