Publication date: 11/29/2021
Comparison Circles
Comparison circles are a graphical representation of the least significant difference (LSD) in a multiple comparison test. This least significant difference is a Student’s t-statistic multiplied by the standard error of the difference of the two means and is defined as follows:
Equation shown here
The standard error of the difference of two independent means is calculated from the following relationship:
Equation shown here
When the means are uncorrelated, these quantities have the following relationship:
Equation shown here
These squared values form a Pythagorean relationship, illustrated graphically by the right triangle shown in Figure 6.44.
Figure 6.44 Relationship of the Difference between Two Means
The hypotenuse of this triangle is a measuring stick for comparing means. The means are significantly different if and only if the actual difference is greater than the hypotenuse (LSD).
Suppose that you have two means that are exactly on the borderline, where the actual difference is the same as the least significant difference. Draw the triangle with vertices at the means measured on a vertical scale. Also, draw circles around each mean so that the diameter of each is equal to the confidence interval for that mean.
Figure 6.45 Geometric Relationship of t Test Statistics
The radius of each circle is the length of the corresponding leg of the triangle, which is Equation shown here.
The circles must intersect at the same right angle as the triangle legs, giving the following relationship:
If the means differ exactly by their least significant difference, then the confidence interval circles around each mean intersect at a right angle. That is, the angle of the tangents is a right angle.
Now, consider how these circles must intersect if the means are different by greater than or less than the least significant difference:
If the circles intersect so that the outside angle is greater than a right angle, then the means are not significantly different. If the circles intersect so that the outside angle is less than a right angle, then the means are significantly different. An outside angle of less than 90 degrees indicates that the means are farther apart than the least significant difference.
If the circles do not intersect, then they are significantly different. If they nest, they are not significantly different (Figure 6.11).
The same graphical technique works for many multiple-comparison tests, substituting a different probability quantile value for the Student’s t.
