Reliability and Survival Methods > Destructive Degradation > Destructive Degradation Platform Options
Publication date: 11/29/2021
The Degradation Data Analysis red triangle menu contains the following options:
Graph Options
Provides options for modifying the platform graphs.
Shade
Turns the shading on or off. By default, the upper and lower bounds of each shaded band at a given value of time correspond to the 0.025 and 0.975 quantiles of the distribution of Y.
Shade Coverage
If shading is on, you can enter a proportion to increase or decrease the amount of shading coverage.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
