Basic Analysis > Distributions > Distribution Platform Options
Publication date: 11/29/2021
The red triangle menu next to Distributions contains options that affect all of the reports and graphs in the Distribution platform.
Uniform Scaling
Scales all axes with the same minimum, maximum, and intervals so that the distributions can be easily compared.
Stack
Changes the orientation of the histogram and the reports to horizontal and stacks the individual distribution reports vertically. Deselect this option to return the report window to its original layout.
Arrange in Rows
Enter the number of plots that appear in a row. This option helps you view plots vertically rather than in one wide row.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
