Publication date: 11/29/2021
Evaluate the Design
When you click Make Design, in most platforms, a Design Evaluation outline appears. Here you can explore the design that you created in terms of its power to detect effects, its prediction variance, its estimation efficiency, its aliasing relationships, the correlations between effects, and other design efficiency measures. The Design Evaluation outline for a Custom Design is shown in Figure 3.22. Design Evaluation is covered in Evaluate Designs.
For some platforms, other types of design diagnostics are appropriate. For example, Space Filling Design provides a Design Diagnostics outline with metrics specific to space-filling designs. Covering Array provides a Metrics outline with measures that are specific to coverage.
Figure 3.22 Design Evaluation Outline in Custom Design
