Predictive and Specialized Modeling > Functional Data Explorer
Publication date: 11/29/2021
Image shown hereFunctional Data Explorer
Perform Functional Data Analysis
The Functional Data Explorer platform is available only in JMP Pro.
The Functional Data Explorer (FDE) platform is designed for data that are functions, signals, or series. It can be used as an exploratory data analysis tool or as a dimension-reduction technique. In the case of dimension reduction, the FDE platform converts functional data into a form that can be analyzed in another JMP platform.
Data preprocessing tools are available in the FDE platform, including several types of transformations for output data and alignments for input data. A functional model is created by fitting a B-spline, P-spline, or Fourier basis model to the data. When a model is fit, functional principal components analysis (functional PCA) is automatically performed on the functional model. Results from the functional PCA, such as the functional principal component scores, are saved to a separate data table for feature extraction or dimension reduction.
Figure 16.1 B-Spline Model Selection in FDE
Contents
Overview of the Functional Data Explorer Platform
Example of Functional Data Explorer
Launch the Functional Data Explorer Platform
The Functional Data Explorer Report
Model Reports
Functional Data Explorer Platform Options
Functional Data Explorer Group Options
Data Processing Report Options
Model Report Options
Additional Examples of the Functional Data Explorer Platform
Example for Multiple Functional Processes
Example of Functional DOE
Statistical Details for the Functional Data Explorer Platform
Functional Model Fits
Function Summaries Details
