Predictive and Specialized Modeling > Functional Data Explorer > Functional Data Explorer Platform Options
Publication date: 11/29/2021
Image shown hereFunctional Data Explorer Platform Options
The Functional Data Explorer red triangle menu contains the following options:
Summaries
A submenu of the following options for functional summary statistics:
Plot Mean
Shows or hides a plot of the functional mean in the Summaries report. On by default.
Plot Standard Deviation
Shows or hides a plot of the functional standard deviation in the Summaries report. On by default.
Plot Median
Shows or hides a plot of the functional median in the Summaries report.
Models
A submenu of the following model options:
B-Splines
Fits a basis spline (B-Spline) model to the data. Use the B-Spline model for non-periodic data.
P-Splines
Fits a penalized basis spline (P-Spline) model to the data.
Fourier Basis
Fits a Fourier Basis model to the data. Use the Fourier Basis model for periodic data. A periodic model assumes that the function finishes where it starts. See Fourier Basis Model.
Note: If there are fewer than three unique input values, neither a Fourier basis model or a P-Spline model can be fit to the data, and a warning message appears.
Model Controls
Shows a submenu that enables you to open the Model Controls panel prior to fitting a model. See Model Controls.
Direct Functional PCA
(Not available if there is only a single function.) Performs functional principal components analysis directly on the data, without fitting a basis function model first. This reduces computation time, particularly for large data sets. The implementation of Direct Functional PCA is as follows:
1. Align the input data to be between 0 and 1 and interpolate the observations to a common grid of input values.
2. Perform functional principal components analysis on the data.
3. Smooth the first eigenfunction using a P-Spline model with a knot at each grid point.
4. Remove the first smoothed eigenfunction from the data and repeat step 2 to step 4 until a large amount of the variation in the data is explained.
Once you perform a Direct Functional PCA, a Functional PCA report is shown. See Functional PCA.
Save Data
Saves the processed data to a new data table. The processed data are saved in the stacked data format.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
