Use Graph Builder to interactively explore your data. You can quickly create and experiment with plots until you find the one you want. Then, you can share your results with others.
This chapter shows you how to use Graph Builder. For detailed examples using Graph Builder, see Graph Builder Examples.
Figure 3.1 Graphs Created in Graph BuilderĀ
