Numerous options are contained in Graph Builder right-click menus. The specific menu options depend on where in a graph you click, and the types and number of variables in your graph. Descriptions for the right click menu options are grouped in the following categories.
• Options for Columns in the Variables Panel
• Options for Axes, Axes Variable Labels, or Graph Titles
• Options for the Dividing Line between Multiple Graphs
For multiple graphs (created with grouping zones or the Wrap zone), note the following:
• Generally, any options that you apply to one graph element apply to all graphs, across all grouping and wrap variables.
• To apply an option to only one graph, right-click in that graph area and select the option from the Graph menu.
• To apply an option to all of your multiple graphs simultaneously, first hold down the Ctrl key and right-click and then select the option from the Graph menu.
