Multivariate Methods > K Means Cluster > Iterative Clustering Report
Publication date: 11/29/2021
When you click OK in the launch window, the Iterative Clustering report window appears, showing a Control Panel for fitting models. See Iterative Clustering Control Panel. As you fit models, additional reports are added to the window. See K Means Report.
Iterative Clustering Options
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
