Basic Analysis > Logistic Analysis > Logistic Platform Options
Publication date: 11/29/2021
The Logistic Fit red triangle menu contains options that affect the Logistic plot. If you have specified multiple Y response variables, the Fit Group red triangle menu appears instead. See Fit Group Options in Fitting Linear Models.
Odds Ratios
Adds odds ratios to the Parameter Estimates report. See Odds Ratios in Fitting Linear Models.
This option is available only for a response with two levels.
Inverse Prediction
Prediction of x values from given y values. See Inverse Prediction.
This option is available only for two-level nominal responses.
Logistic Plot
Shows or hides the logistic plot.
Plot Options
Contains the following options:
Show Points
Shows or hides the points in the logistic plot.
Show Rate Curve
Is useful only if you have several points for each x-value. In these cases, you get reasonable estimates of the rate at each value, and compare this rate with the fitted logistic curve. To prevent too many degenerate points, usually at zero or one, JMP shows only the rate value if there are at least three points at the x-value.
Line Color
Enables you to select the color of the plot curves.
ROC Curve
Produces a Receiver Operating Characteristic (ROC) curve. The ROC curve is a plot of sensitivity versus (1 - specificity) for each value of x. See ROC Curves.
Lift Curve
Produces a lift curve for the model. A lift curve shows the same information as a ROC curve, but in a way to dramatize the richness of the ordering at the beginning. The vertical axis shows the ratio of how rich that portion of the population is in the chosen response level compared to the rate of that response level as a whole. See Lift Curve in Fitting Linear Models for more information about lift curves.
Save Probability Formula
Creates new data table columns that contain formulas. See Save Probability Formula.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
