Predictive and Specialized Modeling > Make Validation Column > Make Validation Column Platform Options
Publication date: 11/29/2021
Image shown hereMake Validation Column Platform Options
The Make Validation Column Utility has the following red triangle menu options:
See Redo Menus in Reports and Save Script Menus in Reports in Using JMP for more information about the following options:
Redo
Save Script
