Publication date: 11/29/2021
Matched Pairs Platform Options
The Matched Pairs red triangle menu contains the following options:
Plot Dif by Mean
Shows or hides the plot of the paired differences by paired means. For a detailed description of this plot, see Difference Plot and Report.
Plot Dif by Row
Shows or hides the plot of paired differences by row number.
Reference Frame
Shows or hides the reference frame on the Plot Dif by Mean plot. A rectangle showing where a plot of Y2 by Y1 would be located inside the plot, tilted and possibly squished. A vertical red line is shown representing the mean of means. The reference frame is shown initially when the range of the differences is greater than half the range of the data.
Wilcoxon Signed Rank
Shows or hides the Wilcoxon signed rank test. The Wilcoxon signed rank test is applied to the paired differences. It is a nonparametric test that compares the sizes of the positive differences to the sizes of the negative differences. The test uses the Pratt method to address zero differences. The test also assumes that the distribution of differences is symmetric. See Distributions in Basic Analysis. See also Lehman (2006), Conover (1999, p. 350), and Cureton (1967).
Sign Test
Shows or hides the sign test. This is a nonparametric version of the paired t test that uses only the sign (positive or negative) of the difference for the test.
Set α Level
Changes the alpha level used in the analyses. Affects the confidence intervals in the report and on the plot.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
