Predictive and Specialized Modeling > Fit Curve > Statistical Details for the Fit Curve Platform
Publication date: 11/29/2021
Model Formulas
Table 14.1 provides the formulas for the models on the Fit Curve red triangle menu.
Table 14.1 Fit Curve Model Formulas
Model
Formula
Polynomials
Equation shown here
where k is the order of the polynomial. These models can also be fit using the Fit Model and Fit Y by X platforms.
Logistic 2P
Equation shown here
a = Growth Rate
b = Inflection Point
Available only when all response values are between zero and one.
Logistic 3P
Equation shown here
a = Growth Rate
c = Asymptote
Logistic 4P
Equation shown here
a = Growth Rate
c = Lower Asymptote
d = Upper Asymptote
Logistic 4P Rodbard
Equation shown here
a = Growth Rate
c = Lower Asymptote
d = Upper Asymptote
Available only when the regressor values are positive.
Logistic 4P Hill
Equation shown here
a = Growth Rate
c = Lower Asymptote
d = Upper Asymptote
Logistic 5P
Equation shown here
a = Growth Rate
c = Asymptote 1
d = Asymptote 2
f = Power
Probit 2P
Equation shown here
a = Growth Rate
Φ = Normal Distribution CDF
Probit 4P
Equation shown here
a = Growth Rate
c = Asymptote 1
d = Asymptote 2
Gompertz 3P
Equation shown here
a = Asymptote
b = Growth Rate
c = Inflection Point
Gompertz 4P
Equation shown here
a = Lower Asymptote
b = Upper Asymptote
c = Growth Rate
d = Inflection Point
Weibull Growth
Equation shown here
a = Upper Asymptote
b = Growth Rate
Available only when both the response values and regressor values are non-negative.
Exponential 2P
Equation shown here
a = Scale
b = Growth Rate
Exponential 3P
Equation shown here
a = Asymptote
b = Scale
c = Growth Rate
Biexponential 4P
Equation shown here
a = Scale 1
b = Decay Rate 1
c = Scale 2
d = Decay Rate 2
Available only when the response values are positive.
Biexponential 5P
Equation shown here
a = Asymptote
b = Scale 1
c = Decay Rate 1
d = Scale 2
f = Decay Rate 2
Mechanistic Growth
Equation shown here
a = Asymptote
b = Scale
c = Growth Rate
Cell Growth 4P
Equation shown here
a = Peak value if mortality rate, d, is zero
b = Response at time zero
c = Cell Division Rate
d = Cell Mortality Rate
Available only when the response values are positive and the regressor values are non-negative.
Gaussian Peak
Equation shown here
a = Peak Value
b = Critical Point
c = Growth Rate
Lorentzian Peak
Equation shown here
a = Peak Value
b = Growth Rate
c = Critical Point
One Compartment Oral Dose
Equation shown here
a = Area Under Curve
b = Elimination Rate
c = Absorption Rate
Available only when the response values and the regressor values are all positive.
Two Compartment IV Bolus Dose
Equation shown here
α =Equation shown here
β =Equation shown here
a = Initial Concentration
b = Transfer Rate In
c = Transfer Rate Out
d = Elimination Rate
Michaelis-Menten
Equation shown here
a = Max Reaction Rate
b = Inverse Affinity
