Publication date: 11/29/2021
Model Selection and Deviance
An important aspect of generalized linear modeling is the selection of explanatory variables in the model. Changes in goodness-of-fit statistics are often used to evaluate the contribution of subsets of explanatory variables to a particular model. The deviance is defined to be twice the difference between the maximum attainable log-likelihood and the log-likelihood at the maximum likelihood estimates of the regression parameters. The deviance is often used as a measure of goodness of fit. The maximum attainable log-likelihood is achieved with a model that has a parameter for every observation. Table 12.4 lists the deviance formula for each of the available distributions for the response variable.
Table 12.4 Deviance Formulas for Response Distributions
Distribution
Deviance Formula
Normal
Equation shown here
Binomial
Equation shown here
Poisson
Equation shown here
Exponential
Equation shown here
The Pearson chi-square statistic is defined as follows:
Equation shown here
where
yi is the ith response
μi is the corresponding predicted mean
V(μi) is the variance function
wi is a known weight for the ith observation
Note: If no weight is specified, wi = 1 for all observations.
One strategy for variable selection is to fit a sequence of models. You start with a simple model that contains only an intercept term, and then include one additional explanatory variable in each successive model. You can measure the importance of the additional explanatory variable by the difference in deviance or fitted log-likelihood values between successive models. Asymptotic tests enable you to assess the statistical significance of the additional term.
When the distribution is non-normal, a normal critical value is used instead of a t-distribution critical value in inverse prediction.
Residual Formulas
Deviance
Equation shown here
Studentized Deviance
Equation shown here
Pearson
Equation shown here
Studentized Pearson
Equation shown here
where
(yiμi) is the raw residual
sign(yiμi) is 1 if (yiμi) is positive and -1 if (yiμi) is negative
di is the contribution to the total deviance from observation i
φ is the dispersion parameter
hi is the ith diagonal element of the matrix We(1/2)X(X'WeX)-1X'We(1/2), where We is the weight matrix used in computing the expected information matrix.
For more information about residuals and generalized linear models, see the GENMOD Procedure chapter in SAS Institute Inc. (2020a).
