Publication date: 11/29/2021
Neural Platform Options
The Neural red triangle menu contains the following options:
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
