Predictive and Specialized Modeling > Nonlinear Regression
Publication date: 11/29/2021
Fit Custom Nonlinear Models to Your Data
The Nonlinear platform is a good choice for models that are nonlinear in the parameters. This chapter focuses on custom nonlinear models, which include a model formula and parameters to be estimated. Use the default least squares loss function or a custom loss function to fit models. The platform minimizes the sum of the loss function across the observations.
Figure 15.1 Example of a Custom Nonlinear FitĀ
The Nonlinear platform also provides predefined models, such as polynomial, logistic, Gompertz, exponential, peak, and pharmacokinetic models. See Fit Curve.
Note: Some models are linear in the parameters (for example, a quadratic or other polynomial) or can be transformed to be such (for example, when you use a log transformation of x). The Fit Model or Fit Y by X platforms are more appropriate in these situations. For more information about these platforms, see Model Specification in Fitting Linear Models and Introduction to Fit Y by X in Basic Analysis.
Contents
Example of Fitting a Custom Model
Launch the Nonlinear Platform
The Nonlinear Fit Report
Nonlinear Platform Options
Create a Formula Using the Model Library
Customize the Nonlinear Model Library
Additional Examples
Example of Maximum Likelihood: Logistic Regression
Example of a Probit Model with Binomial Errors: Numerical Derivatives
Example of a Poisson Loss Function
Example of Setting Parameter Limits
Statistical Details for the Nonlinear Platform
Profile Likelihood Confidence Limits
How Custom Loss Functions Work
Notes Concerning Derivatives
Notes on Effective Nonlinear Modeling
