Profilers > Introduction to Profilers > Profiler Platform Options
Publication date: 11/29/2021
The Profiler red triangle menu contains the following options:
Profiler
Shows or hides the Prediction Profiler.
Contour Profiler
Shows or hides the Contour Profiler.
Custom Profiler
Shows or hides the Custom Profiler.
Surface Profiler
Shows or hides the Surface Profiler.
Mixture Profiler
Shows or hides the Mixture Profiler.
Show Formulas
Opens a JSL window showing all formulas being profiled.
Formulas for OPTMODEL
Creates code for the OPTMODEL SAS procedure. Press Ctrl+Shift and then select Formulas for OPTMODEL from the red triangle menu.
The following options are available in many platforms. See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP.
Redo
Save Script
