Using JMP > Save and Share Your Data > Save and Share Data Tables
Publication date: 11/29/2021
Select File > Export or File > Save As to save a data table in another format such as Microsoft Excel or CSV.
Note: To save a data table as a journal, select Edit > Journal and then File > Save As.
JMP saves data tables in the formats listed in Table 10.1.
Table 10.1 Supported File Types for Saving Data Tables
File Type(s)
OS Availability
JMP Data Table (.jmp)
All
Excel Workbook (.xls, .xlsx)
All
Text Export File (.txt)
All
Comma-delimited File (.csv)
Windows
Tab-delimited File (.tsv)
Windows
SAS Data Set (.sas7bdat)
All
SAS Data Set with Extended Attributes (.sas7bxat)
Note: JMP can save column properties and table properties as extended attributes in a SAS 9.4 .sas7bxat file. Select File > Export, select the SAS file type, and then select the check box for saving extended attributes. JMP names the file with the .sas7bxat extension. The SAS Integration preferences also include this option, which is off by default.
Windows
SAS Transport File (.xpt,.stx)
All
JSON Data File (.json)
All
You can also save files for types that have a corresponding ODBC driver. See Save Data Tables to a Database.
Notes:
The maximum length of the data table’s name depends on your computer’s operating system. See your operation system documentation for details.
JMP tries to save any modified files when a crash is detected.
