Publication date: 11/29/2021
The Manova Fit Options
The following Manova Fit options are available:
Save Discrim
Performs a discriminant analysis and saves the results to the data table. See Discriminant Analysis.
Save Predicted
Saves the predicted responses to the data table.
Save Residuals
Saves the residuals to the data table.
Model Dialog
Shows the completed launch window for the current analysis.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
