Discovering JMP > Analyze Your Data > Understand Modeling Types
Publication date: 11/29/2021
In JMP, data can be of different types. JMP refers to this as the modeling type of the data. Table 5.1 describes the three modeling types in JMP.
Table 5.1 Modeling Types
Modeling Type and Description
Examples
Specific Example
Continuous
Numeric data only. Used in operations like sums and means.
Height
Temperature
Time
The time to complete a test might be 2 hours, or 2.13 hours.
Ordinal
Numeric or character data. Values belong to ordered categories.
Month (1,2,...,12)
Letter grade (A, B,...F)
Size (small, medium, large)
The month of the year can be 2 (February) or 3 (March), but not 2.13. February comes before March.
Nominal
Numeric or character data. Values belong to categories, but the order is not important.
Gender (M or F)
Color
Test result (pass or fail)
The gender can be M or F, with no order. Gender categories can also be represented by a number (M=1 and F=2).
Multiple Response
Character data only. Distinct entries in a single cell that are separated by commas.
When you brush your teeth
College degrees
Sports you play
There are several times a day that you could brush your teeth. First thing in the morning, after breakfast, after meals, before bed, or any combination of the above.
Unstructured Text
Character data only. Usually all unique values that must be analyzed using Text Explorer.
Product reviews
Song lyrics
Free response field in survey
Most product reviews would be unique and Text Explorer is used to determine any underlying similarities.
Vector
Expression data only. Values in a cell are column or row vectors.
Prediction formulas
None
Any data type. Used in scenarios where a column is not well represented by the other modeling types.
Pictures
ID Values
A picture column in a data table would not be used to modeling, but could be used as a marker on a graph for example.
