Publication date: 11/10/2021
Control Limits for XBar and R Charts
JMP generates control limits for XBar and R charts using the following formulas:
LCL for XBar chart = Equation shown here
UCL for XBar chart = Equation shown here
LCL for R chart = Equation shown here
UCL for R chart = Equation shown here
Center line for R chart: By default, the center line for the ith subgroup indicates an estimate of the expected value of Ri. This value is computed as Equation shown here, where Equation shown here is an estimate of σ.
The standard deviation for XBar and R charts is estimated using the following formula:
Equation shown here
where:
Equation shown here = weighted average of subgroup means
K = the sigma multiplier and is set to 3 by default
σ = process standard deviation
ni = sample size of ith subgroup
d2(n) is the expected value of the range of n independent normally distributed variables with unit standard deviation
d3(n) is the standard deviation of the range of n independent normally distributed variables with unit standard deviation
Ri is the range of ith subgroup
N is the number of subgroups for which ni ≥ 2.
