Quality and Process Methods > Control Chart Builder
Publication date: 11/10/2021
Create Control Charts Interactively
A control chart is a graphical and analytic tool for monitoring process variation. The natural variation in a process can be quantified using a set of control limits. Control limits help distinguish common-cause variation from special-cause variation. Typically, action is taken to identify and eliminate special-cause variation. It is also important to quantify the common-cause variation in a process, as this determines the capability of a process.
Use Control Chart Builder to create control charts of your process data. Control Chart Builder can be launched as an interactive workspace or from specific control chart menu options. In the interactive workspace, you select the variables that you want to chart and drag them into zones. JMP automatically chooses an appropriate chart type based on the data. You can quickly create another type of chart, or change the current settings for an existing chart.
Figure 3.1 Control Chart Builder Example
Contents
Overview of Control Chart Builder
Example of Control Chart Builder
Control Chart Types
Shewhart Control Charts for Variables
Shewhart Control Charts for Attributes
Rare Event Control Charts
Control Chart Types
Launch Control Chart Builder
Control Chart Builder Interactive Workspace
Launch Windows for Specific Control Charts
Control Chart Builder Window
Control Chart Builder Options
Control Chart Builder Red Triangle Menu Options
Options Panel and Right-Click Chart Options
Control Chart Builder Right-Click Axis Options
Work with Control Limits
Example of Control Limits
Excluded and Hidden Samples in Control Chart Builder
Additional Examples of Control Chart Builder
Individual Measurement and Moving Range Charts Example
XBar and R Chart Phase Example
XBar and S Charts with Varying Subgroup Sizes Example
Run Chart Example
P chart Example
NP chart Example
C chart Example
U chart Example
G chart Example
T chart Example
Three Way Control Chart Example
Example of Multiple Control Charts
Statistical Details for Control Chart Builder
Control Limits for XBar and R Charts
Control Limits for XBar and S Charts
Control Limits for Individual Measurement and Moving Range Charts
Control Limits for P and NP Charts
Control Limits for U Charts and C Charts
Levey-Jennings Charts
Control Limits for G Charts
Control Limits for T Charts
Sigma Calculations for Three Way Control Charts
