Use the buttons to finish your MSA design construction.
Make Table
Constructs the MSA design data table. In addition to the design, the table includes a run order column, a replicates column, and the following scripts for analysis:
EMP Measurement Systems Analysis
Variability Chart
Launches the Variability Gauge Chart platform. See Variability Gauge Charts.
DOE Dialog
Launches the MSA Design platform with the specifications used to generate the current design table.
Operator Worksheets
Opens a data table for each operator to use as a worksheet for data collection.
Back
Takes you back to make adjustments to the design specifications.
