This section contains examples using Control Chart Builder.
Note: In this section, some examples show the Control Panel while others do not. To show or hide the Control Panel, select Show Control Panel from the Control Chart Builder red triangle menu.
• Example of Individual Measurement and Moving Range Charts
• Example of an XBar and R Chart
• Example of XBar and R Charts with Varying Subgroup Sizes
