Publication date: 06/21/2023
Example of a Run Chart
In this example, you use the Run Chart launch window to launch Control Chart Builder. Run charts display a column of data as a connected series of points.
1. Select Help > Sample Data Folder and open Stock Averages.jmp.
2. Select Analyze > Quality and Process > Control Chart > Run Chart.
3. Select Close and click Y.
4. Click OK.
Figure 3.22 Run Chart for Stock Averages Closing PriceĀ
