Publication date: 06/21/2023
Data Entry
Enter, load, or simulate DOE response data on the Data Entry tab of Easy DOE. You can enter responses directly in the columns for the response(s) that you defined on the Define tab.
Tips:
After entering data, Save the entries to your file (File > Save).
Data tables have limited capabilities. Export the data table for full functionality.
To add additional responses, add them on the Define Tab.
Response(s)
The Response side of the data entry table allows you to add the results from your design.
Export Data
Exports the design and responses to a standalone JMP data table.
Load Responses
Load responses from a JMP data table.
Design
The Design side of the data entry table displays the design.
Show/Hide simulation panel
Shows or hides the simulation panel. Use to simulate data for your design.
Simulation Panel
Use the simulation panel to simulate data for your design. This feature is useful for teaching or to investigate the design for expected data. To specify specific model effects, enter values for the coefficients for each model term and click Simulate Response. Use the Zero Coefficients button to reset the coefficients to zero. Use the Random Coefficients button to randomly set a few coefficients to nonzero, and then click Simulate Response.
Note: The Normal Error σ is the anticipated root mean square error.
Factor Plots
The Easy DOE factor plots show each response plotted against each factor. Prior to data entry, the plots show the level of each factor. The Y axis has no values. After data entry, the plots have a line connecting the mean response of each x level.
