Publication date: 06/21/2023
Easy DOE
End-to-End Guided Design of Experiment Tool
Use the Easy DOE platform for an end-to-end guided design of experiment solution. Define design, enter data, and analyze an experiment in a single JMP platform. Use the guided mode for assistance as you move through the design and analysis steps. Use the flexible mode to proceed on your own. Save your progress as you go, return for analysis or to share with other JMP users. Export a report after the analysis is complete.
Figure 7.1 Easy DOE Response Strength PlotĀ
Contents
Overview of the Easy DOE Platform
Example of Easy DOE
Design with the Easy DOE Platform
Define
Model
Design
Data Entry
Analyze
Predict
Report
Statistical Details for the Easy DOE Platform
Easy DOE Design Selection Rules
Statistical Details for Easy DOE Analyze Tab
