Predictive and Specialized Modeling > Explore Outliers > Explore Outliers Platform Options
Publication date: 06/21/2023
The Explorer Outliers red triangle menu contains the following options:
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
