Publication date: 06/21/2023
k Sample Means Calculator
Use the k Sample Means legacy calculator to determine an appropriate sample size for a hypothesis test about two to ten means. For more information about calculations in JMP, see Barker (2011, Section 2.3).
Tip: To calculate sample sizes for k sample means, consider using DOE > Sample Size Explorers > Power > Power for ANOVA. See “Power for ANOVA”.
