The Sample Size and Power platform is deprecated, meaning it is an older platform that contains features that can be accessed in a newer platform. This legacy platform might not be available in future releases of JMP. Sample size and power calculators are now available in the Sample Size Explorers platform. Select DOE > Sample Size Explorers for sample size calculations.
For sample size and power calculators see “Sample Size Explorers”.
Calculator |
Sample Size Explorers |
One Sample Mean |
Two Sample Mean |
k Sample Means |
One Sample Standard Deviation |
One Sample Proportion |
Two Sample Proportions |
Counts per Unit |
“Power for One Sample Counts Per Unit” “Power for Two Independent Sample Counts Per Unit” |
Reliability Demonstration |
“Parametric Reliability Demonstration” |
Sigma Quality Level |
