Predictive and Specialized Modeling > Naive Bayes > Naive Bayes Platform Options
Publication date: 06/21/2023
Image shown hereNaive Bayes Platform Options
The Naive Bayes red triangle menu contains the following options:
ROC Curve
Shows or hides the ROC plot. The ROC plot is shown by default. See ROC Curves.
Lift Curve
Shows or hides the lift curve for the model. If you used validation, Lift curve is shown for each of the Training, Validation, and Test sets, if specified.
A lift curve shows how effectively response levels are classified as their fitted probabilities decrease. The fitted probabilities are plotted along the horizontal axis in descending order. The vertical coordinate for a fitted probability is the proportion of correct classifications for that probability or higher, divided by the overall correct classification rate. Use the lift curve to see whether you can correctly classify a large proportion of observations if you select only those with a fitted probability that exceeds a threshold value.
If the response has two levels, the Lift curve plot displays a lift curve for the first level of the response only. If the response has more than two levels, the Lift curve plot displays a sub-outline of the curves for each response level. See Lift Curve for more information about lift curves.
Save Predicteds
Saves the predicted classifications to the data table in a column called Naive Predicted <Y, Response>.
Save Prediction Formula
Saves a column called Naive Predicted Formula <Y, Response> to the data table. This column contains the prediction formula for the classifications.
Save Probability Formula
Saves columns to the data table that contain formulas used for classifying each observation. Three groups of columns are saved:
Naive Score <Class>, Sum
For each column that represents a class, this column gives a score formula that measures strength of membership in the given class. In the Naive Score Sum column., these scores are summed across classes. See Statistical Details for Saved Probability Formulas.
Naive Prob <Class>
For each class, this column gives a formula for the conditional probability that an observation is in that class. See Statistical Details for Saved Probability Formulas.
Gives the formula for the predicted class.
Publish Probability Formula
Creates probability formulas and saves them as formula column scripts in the Formula Depot platform. If a Formula Depot report is not open, this option opens the Formula Depot window. See Formula Depot.
Profiler
Shows or hides an interactive profiler report. Changes in the factor values are reflected in the estimated classification probabilities. See Profiler in Profilers.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
