The Compare Designs platform, which is an extension of the Evaluate Design platform, enables you to easily compare up to four designs to a reference design. To compare the performance of one or two designs relative to another, you select a reference design that is treated as the base design. You can specify effects in the Model section, and effects of interest in the Alias Terms section.
The Design Evaluation report shows diagnostic results and plots covering these areas:
• Power analysis
• Prediction variance
• Fraction of design space
• Relative estimation efficiency
• Alias matrix diagnostics
• Correlations among effects (including confounding)
• Relative efficiency measures for the overall designs
