Design of Experiments Guide > Compare Designs
Publication date: 06/21/2023
Compare Designs
Compare and Evaluate Designs Simultaneously
The Compare Designs platform compares up to four designs to a reference design. Use to explore, evaluate, and compare design performance. Diagnostics show how the designs perform relative to each other and how they perform in an absolute sense. To compare designs relative to your specific needs, you can change the terms in the assumed model and in the alias terms list.
Figure 17.1 Comparing Three Designs with Different Run SizesĀ
Contents
Overview of the Compare Designs Platform
Examples of Comparing Designs
Example Using Designs of the Same Run Size
Example Using Designs of Different Run Sizes
Example of Split Plot Designs with Different Numbers of Whole Plots
Launch the Compare Designs Platform
Specify Model and Alias Terms in the Compare Designs Platform
Reference Design
Factors
Model
Alias Terms
Design Evaluation in the Compare Designs Platform
Power Analysis
Prediction Variance Profile
Fraction of Design Space Plot
Relative Estimation Efficiency
Alias Matrix Summary
Absolute Correlations
Design Diagnostics
Compare Designs Options
