There are several profilers in JMP and each have a different set of features. The profilers are accessible from most fitting platforms and the main menu under Graph. When you launch a profiler from the Graph menu, you must specify formula columns.
Description |
Features |
Prediction Profiler |
Shows vertical slices across each factor, holding other factors at current values |
Desirability, Optimization, Simulator, Propagation of Error |
Contour Profiler |
Horizontal slices show contour lines for two factors at a time |
Simulator |
Surface Profiler |
3-D plots of responses for 2 factors at a time, or a contour surface plot for 3 factors at a time |
Surface Visualization |
Mixture Profiler |
A contour profiler for mixture factors |
Ternary Plot and Contours |
Custom Profiler |
A non-graphical profiler and numerical optimizer |
General Optimization, Simulator |
Excel Profiler |
Visualize models (or formulas) stored in Excel worksheets. |
Profile using Excel Models |
Profiler availability is shown in Table 2.2. The Custom Profiler is available only through the Graph menu. (Model Comparison does have Custom Profiler available.)
Location |
Profiler |
Contour Profiler |
Surface Profiler |
Mixture Profiler |
Graph Menu (as a Platform) |
Yes |
Yes |
Yes |
Yes |
Fit Model: Least Squares |
Yes |
Yes |
Yes |
Yes |
Fit Model: Generalized Regression |
Yes |
Fit Model: Mixed Model |
Yes |
Yes |
Yes |
Yes |
Fit Model: Logistic |
Yes |
Fit Model: Loglinear Variance |
Yes |
Yes |
Yes |
Fit Model: Generalized Linear Model |
Yes |
Yes |
Yes |
Fit Model: Partial Least Squares |
Yes |
Neural |
Yes |
Yes |
Yes |
Partition |
Yes |
Bootstrap Forest |
Yes |
Boosted Tree |
Yes |
Support Vector Machines |
Yes |
Yes |
Yes |
Model Screening |
Yes |
Model Comparison |
Yes |
Yes |
Yes |
Yes |
Nonlinear: Factors and Response |
Yes |
Yes |
Yes |
Nonlinear: Parameters and SSE |
Yes |
Yes |
Yes |
Nonlinear: Fit Curve |
Yes |
Functional Data Explorer |
Yes |
Gaussian Process |
Yes |
Yes |
Yes |
Discriminant |
Yes |
Yes |
Structural Equation Models |
Yes |
Life Distribution |
Yes |
Fit Life by X |
Yes |
Yes |
Recurrence Analysis |
Yes |
Choice |
Yes |
Custom Design Prediction Variance |
Yes |
Yes |
