Compare Design uses a reference design. The Reference Design section includes the name of the reference design. The Matching Specification section lists the specifications for the comparison designs from the launch window.
Use the Compare Designs Factors section to add effects to the Model and Alias Terms lists.
The Factors section lists the factors, using the column names from the reference design, and coded values. Because they are not factors, whole plot and subplot columns do not appear in the Factors section. However, they are required for the analysis.
