Using JMP > Save and Share Your Data
Publication date: 06/21/2023
Get Your Data Out of JMP
This chapter describes how to save data tables in different formats, save your JMP analyses as scripts, or save your JMP sessions. You also learn how to share reports interactively on the web, or as JMP journals or projects.
When choosing how to share your content, consider the following:
If you want to interactively share your data, even with people who do not use JMP, you might choose to share it to JMP Live or JMP Public, or as an interactive HTML page.
If you want to present your data, you might choose to create a JMP journal.
If you want to send data tables, linked reports, and other items to another JMP user, you might choose to bundle all these files as a JMP project.
Contents
Save Data Tables
Save Data Tables as Microsoft Excel Files
Save JMP Data as a CSV File
Save JMP Data as a Text File
Save JMP Data as a JSON File
Save JMP Data as a SAS Transport File
Save JMP Data as a Google Sheet
Save JMP Data as a SAS Data Set
Save Data Tables to a Database
Replace a Database with a Data Table
Save Reports
Save Reports as PDF Files
Save Reports as PowerPoint Presentations
Set the Graphic DPI for Exported Graphics
Save a JMP Analysis as a Script
Save Parts of a Report in a Graphic Format
Share Interactive Reports and Data
Share Reports as Interactive HTML
Share Reports to JMP Live or JMP Public
Share Data to JMP Live
Print Reports
Copy and Paste Reports
Work with Projects
Create a New Project
Open Files in a Project
Rearrange Files in Projects
Save a Project
Project Workspace
Project Bookmarks
Project Contents
Recent Files in Projects
Project Log
Move Files into Projects
Write a Project On Open Script
Example of Creating a New Project
Create Journals
Example of Making a Journal for a Presentation
Create New Journals
Manage Links in Shared Journals
Add and Edit Outlines to Journals
Right-Click Options in Journals
Control the Display of Outline Levels in Journals
Add a Graph or Graphic to Journals
Customize Items in Journals
Prevent Modifications to Journals
Append Reports to Journals
Save Journals in Other Formats
Delete Items from Journals
Save JMP Sessions
Save Sessions upon Exiting JMP
Save Sessions Manually
Save a Log Window
