Discovering JMP > Save and Share Your Work
Publication date: 06/21/2023
Save and Re-create Results
Once you have generated results from your data, JMP provides you with multiple ways to share your work with others. Here are some of the ways that you can share your work:
Saving platform results as journals, projects, or web reports
Saving results, data tables, and other files in projects
Saving scripts to reproduce results in data tables
Saving results as Interactive HTML (.htm, html)
Saving results as a PowerPoint presentation (.pptx)
Sharing results in a dashboard
Re-creating and sharing results in a workflow
Figure 7.1 Example of a Web Report
Contents
Work with Projects
Create a New Project
Open Files in a Project
Rearrange Files in Projects
Save a Project
Project Workspace
Project Bookmarks
Project Contents
Recent Files in Projects
Project Log
Move Files into Projects
Write a Project On Open Script
Example of Creating a New Project
Save Platform Results in Journals
Example of Creating a Journal
Add Analyses to a Journal
Save and Run Scripts
Example of Saving and Running a Script
About Scripts and JSL
Save Reports as Interactive HTML
Interactive HTML Contains Data
Example of Creating Interactive HTML
Share Reports as Interactive HTML
Save a Report as a PowerPoint Presentation
Create Dashboards
Example of Combining Windows
Example of Creating a Dashboard with Two Reports
Recreate JMP Steps in a Workflow
Example of Capturing a JMP Workflow
