Genetics > Marker Simulation > The Marker Simulation Report
Publication date: 06/21/2023
The Marker Simulation platform provides a convenient method for exploring the expected results of crosses of the different individuals in the study. Running this process generates a report with the following sections:
Summary of Simulation
This section lists the selections made on the platform and the time it took for the simulation to run.
Generation Evaluation Table
The table lists various statistics for each cross:
Cross
This column lists the cross numbers, starting at 1, up to the total of crosses.
Mother Sex
This column lists the sex of the mother in the initial cross. This column name changes according to the name of column entered in Cross option. In this example, the column name was Sex, so Mother Sex appears. It always Mother + Name of column in Cross option.
Father Sex
This column lists the sex of the father in the initial cross. This column name changes according to the name of column entered in Cross option. In this example, the column name was Sex, so Father Sex appears. It always Father + Name of column in Cross option.
Generation
This column lists the generation the specific progeny is part of.
Minor Allele Frequency (MAF) Mean
This column shows the average MAF across all markers. The MAF represents the proportion of the minor allele for each marker in the observed population. Assuming a biallelic marker locus M with alleles M1 and M2. A sample of N individuals of even ploidy k can therefore have k+1 different genotypes at the locus. The number of individuals with i (i=0,1, 2, …,k) copies of allele M1 and j (j=0,1, 2, …,k) copies of allele M2 is denoted by Nij. The number n1 of copies of allele M1 can be found directly by summation: n1= 0*N00 + 1*N10 + 2*N20 + … + k*Nk0. The sample frequency of allele M1 is written as p1 = n1/(k*n), frequency of allele M2 is written as p2 = 1- p1, and the sample frequency for each genotype carrying u copies of allele M1 and v copies of allele M2 is written as Pij= Nij /n).
Polymorphism Information Content (PIC) Mean
This column shows the average PIC across all markers. The PIC (Botstein et al., 1980; Hilderbrand, Torney, and Wagner, 1992) measures the probability of differentiating the allele transmitted by a given parent to its child given the marker genotype of father, mother, and child.
PIC= 1 - (p12 + p22) - (p12 + p22)2 + (p14 + p24)
Heterozygosity (HET) Mean
This column shows the average HET across all markers. The heterozygosity, sometimes called the observed heterozygosity, is simply the proportion of heterozygous individuals in the observed population.
HET = 1 - Pii - Pjj (i<j)
Allelic Diversity Mean
This column shows the average allelic diversity across all markers. The allelic diversity, sometimes called the expected heterozygosity, is the expected proportion of heterozygous individuals in the data set when Hardy-Weinberg equilibrium holds.
Div = 1 - p12 - p22
Pred Formula Trait Mean
This column lists the mean of the predicted trait value for the progeny each cross at each generation.
Pred Formula Trait Standard Error of Mean
This column lists the standard error of the mean of the predicted trait value for the progeny each cross at each generation. This value provides a measure of the expected variability.
Scatterplot Matrix
Shows a pairwise comparison of the traits. See Compare Multiple Variables Using Scatterplots in Discovering JMP.
Generation Trait Evaluation Plots
These plots show how the mean trait values compare and trend across generations.
Note: These plots are not shown when the simulation is run for one generation only or when the total number of crosses exceeds the specified display threshold.
Generation Diversity Evaluation Plots
These plots show how the measures of diversity compare and trend across generations.
Note: You must check the Estimate Diversity check box to view these plots. These plots are not shown when the simulation is run for one generation only or when the total number of crosses exceeds the specified display threshold.
