Use the Two Sample Means legacy calculator to evaluate sample size for a hypothesis test about two means. For more information about calculations in JMP, see Barker (2011, Section 2.2).
Tip: To calculate sample sizes for two sample means, consider using DOE > Sample Size Explorers > Power > Power for Two Independent Sample Means. See “Power for Two Independent Sample Means”.
