Use the Two Sample Proportions legacy calculator to evaluate sample size for a hypothesis test about two proportions. For more information about calculations in JMP, see Barker (2011, Section 3.3).
Tip: To calculate sample sizes for two sample proportions, consider using DOE > Sample Size Explorers > Power > Power for Two Independent Sample Proportions. See “Power for Two Independent Sample Proportions”.
