Design of Experiments Guide > Column Properties
Publication date: 04/21/2023
Column Properties
Understand Column Properties Assigned by DOE
When you construct a design using the DOE platforms, column properties are saved to the data table that contains the resulting design. This appendix provides detail about only those column properties that are saved to designs that the DOE platform constructs. Examples illustrate how each column property is assigned and used by the DOE platforms. Descriptions of column properties not assigned by the DOE platforms are provided in Properties Used in Modeling and DOE in Using JMP.
Some of the column properties described in this appendix are useful in general modeling situations. To use the properties more generally, you can specify them yourself. This ability is particularly useful when your design has not been created by a DOE platform. Some of the examples in this appendix illustrate situations where you add a column property on your own.
Figure A.1 Column Property Asterisks and Column Info Window
Contents
Add and View DOE Column Properties
Response Limits
Example of the Response Limits Column Property
Example of Editing DOE Response Limits
Detection Limits
Units
Functional Response
Design Role
Example of the Design Role Column Property
Coding
Low and High Coded Values
Coding Column Property and Center Polynomials
Example of Coded DOE Factors
Example of Assigning Coding
Mixture
Example of the Mixture Column Property
Factor Changes
Example of the Factor Changes Column Property
Value Order
Example of the Value Order Column Property
Example of Assigning Value Orders
Value Labels
Example of the Value Labels Column Property
RunsPerBlock
Example of the RunsPerBlock Column Property
ConstraintState
Example of the ConstraintState Column Property
