Fitting Linear Models > Standard Least Squares Examples > Example of One-Way Analysis of Variance
Publication date: 04/21/2023
Use the Standard Least Squares personality of the Fit Model platform to fit a one-way analysis of variance model, specifying a continuous response column and a nominal effect column. In a one-way analysis of variance, a different mean is fit to each of the different groups, as identified by a nominal variable.
1. Select Help > Sample Data Folder and open Drug.jmp.
3. Select y and click Y.
4. Select Drug and click Add.
5. Click Run.
In this example, Drug has three levels, a, d, and f. The standard least squares fitting method translates this specification into a linear model: The nominal variables define a sequence of indicator variables, which assume only the values 1, 0, and –1. The linear model is specified as follows:
Equation shown here
where:
yi is the observed response for the ith observation
x1i is the value of the first indicator variable for the ith observation
x2i is the value of the second indicator variable for the ith observation
β0, β1, and β2 are parameters for the intercept, the first indicator variable, and the second indicator variable, respectively
εi are the independent and normally distributed error terms
The first indicator variable, x1, is defined as follows. Note that Drug = a contributes a value 1, Drug = d contributes a value 0, and Drug = f contributes a value –1 to the indicator variable:
Equation shown here
The second indicator variable, x2, is given the following values:
Equation shown here
The estimates of the means for the three levels in terms of this parameterization are defined as follows:
Equation shown here
Equation shown here
Equation shown here
Solving for βi yields the following:
Equation shown here (the average over levels)
Equation shown here
Equation shown here
Therefore, if regressor variables are coded as indicators for each level minus the indicator for the last level, then the parameter for a level is interpreted as the difference between that level’s response and the average response across all levels. See the appendix Statistical Details for additional information about the interpretation of the parameters for nominal factors.
Figure 4.1 shows the Leverage Plot and the LS Means Table for the Drug effect. Figure 4.2 shows the Parameter Estimates and the Effect Tests reports for the one-way analysis of the drug data.
Figure 4.1 Leverage Plot and LS Means Table for Drug
Figure 4.2 Parameter Estimates and Effect Tests for Drug.jmp
The Drug effect can be studied in more detail by using a contrast of the least squares means:
1. Click the Drug red triangle and select LSMeans Contrast.
2. Click the + boxes for drugs a and d, and the - box for drug f to define the contrast that compares the average of drugs a and d to f (shown in Figure 4.3).
3. Click Done.
Figure 4.3 Contrast Example for the Drug Experiment
The Contrast report shows that the LSMean for drug f is significantly different from the average of the LSMeans of the other two drugs.
