Design of Experiments Guide > Easy DOE > Statistical Details for the Easy DOE Platform
Publication date: 04/21/2023
This section contains statistical details for the Easy DOE platform.
Easy DOE Design Selection Rules
Statistical Details for Easy DOE Analyze Tab
Easy DOE constructs designs using either the Custom or Definitive Screening Designers. The general rules are found in the table below. Additional rules determine when a definitive screening design is used.
Table 7.2 Easy DOE Designer Rules
Model
Designer
Main Effects
Custom Design (D-Optimal)
Main Effects with some Two-Factor Interactions
Definitive Screening Design or Custom Design (Alias Optimal)
Main Effects and Two-Factor Interactions
Response Surface Design
Custom Design (I-Optimal)
Easy DOE constructs a definitive screening design if all of the following are true:
There are at least 5 factors
All factors are either continuous or categorical
All categorical factors have 2 levels
There are at most 3 categorical factors
The number of continuous factors is greater than or equal to the number of categorical factors
