Publication date: 04/21/2023
Image shown hereValidation Column Role
One way to create data partitions is to use the Validation Column role. The Validation Column role uses the column’s values to divide the data into parts. The column is assigned using the Validation role in the platform’s launch window. For information about how to create a validation column, see Make Validation Column.
The Validation Column role is available only in JMP Pro. For JMP, see Excluded Rows as Validation Holdback.
Caution: The use of a validation column is platform specific. Different platforms use the levels of the validation column differently. See notes in Table A.1.
Table A.1 Validation Column by Platform
Platform
Train & Evaluate
Train & Tune
Train, Tune, & Evaluate
Notes
Fit Model
Fit Least Squares
Yes
No
No
If there are more than three levels, the validation column is ignored.
Stepwise Regression
No
Yes
Yes
If there are more than three levels, K-Fold Cross-Validation is used.
Logistic Regression
Yes
No
No
Generalized Regression
No
Yes
Yes
Partial Least Squares
No
Yes
Yes
Predictive Models
Neural
No
Yes
Yes
Partition
No
Yes
Yes
If there are more than three levels, the platform only uses rows with the three smallest values.
Bootstrap Forest
No
Yes
Yes
Boosted Tree
No
Yes
Yes
K Nearest Neighbors
No
Yes
Yes
Naive Bayes
No
Yes
Yes
Support Vector Machines
Yes
Yes
Yes
Specialized Models
Functional Data Explorer
Yes
No
No
Must be created as a Grouped Random validation column.
If there are more than two levels, the smallest value defines the training set and all other values define the validation set.
Multivariate Models
Discriminant
Yes
Yes
Yes
No
Yes
Yes
Uplift
No
Yes
Yes
