In the Degradation platform, the Degradation Data Analysis red triangle menu contains the following options:
Path Definition
The Y variable at a given time is assumed to have a distribution. You can model the mean, location parameter, or median of that distribution.
Mean Path
Specifies that the mean is the parameter to be modeled.
Location Parameter Path
Specifies that the location parameter of the distribution is the parameter to be modeled.
Median Path
Specifies that the median of the distribution is the parameter to be modeled.
When the Location Parameter or Median Path option is selected, a menu appears in the Model Specification that enables you to select the distribution of the response.
Degradation Path Style
Contains options for selecting the style of degradation path to fit.
Simple Linear Path
Enables you to fit linear degradation paths and nonlinear paths that can be transformed to linear paths. See Simple Linear Path.
Nonlinear Path
Enables you to fit nonlinear degradation paths. See Nonlinear Path.
Graph Options
Contains options for modifying the appearance of graphs in the report.
Connect Data Markers
Shows or hides lines connecting the points on the Overlay plot.
Show Fitted Lines
Shows or hides the fitted lines on the Overlay plot.
Show Spec Limits
Shows or hides the specification limits on the Overlay plot.
Show Residual Plot
Shows or hides the residual plot.
Show Inverse Prediction Plot
Shows or hides the inverse prediction plot
Show Curve Interval
Shows or hides the confidence intervals on the fitted lines on the Overlay plot.
Curve Interval Alpha
Enables you to change the alpha used for the confidence interval curves.
Show Median Curves
Shows or hides median lines on the plot when the Path Definition is set to Location Parameter Path.
Show Legend
Shows or hides a legend for the markers used on the Overlay plot.
No Tab List
Shows or hides the Residual Plot, Inverse Prediction, and Prediction Graph in tabs or in stacked reports.
Prediction Settings
Contains options for modifying the settings used in the model predictions.
Upper Spec Limit
Specifies the upper specification limit.
Lower Spec Limit
Specifies the lower specification limit.
Censoring Time
Specifies the censoring time. See Inverse Prediction.
Baseline
Specifies the normal use conditions for an X variable in nonlinear degradation paths. A path with this value usually results in an Overlay plot.
Inverse Prediction
Specifies the interval type, alpha level, and one- or two-sided intervals for inverse prediction. To do inverse prediction, you must also specify the lower or upper specification limit. See Inverse Prediction.
Longitudinal Prediction
Specifies the Time value, interval type, and alpha level for longitudinal prediction. See Prediction Graph.
Applications
Contains options for further analysis of the degradation data.
Generate Pseudo Failure Data
Creates a data table giving the predicted time each unit crosses the specification limit. The table contains a Life Distribution or Fit Life by X script that can be used to fit a distribution to the pseudo failure times.
Test Stability
Performs stability analysis. See Stability Analysis in the Degradation Platform.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
