The Fit Curve red triangle menu contains several categories of built-in models. Models that are not available for your particular data are grey menu options. For individual model details and data requirements, see Table 14.1.
Polynomials
Fits first degree to fifth degree polynomials, as well as a Power model.
Sigmoid Curves
Fits Logistic, Probit, Gompertz, and Weibull models. These models are S-shaped and have both upper and lower asymptotes. The Logistic 2P, 3P, and 4P and Probit 2P and 4P models are symmetric. The Logistic 5P, Probit 3P, and both Gompertz models are not symmetric. The Logistic 2P and Probit 2P are available only when the response is between 0 and 1. The Weibull Growth is available only when both the response values and regressor values are nonnegative. Examples of Sigmoid curves include learning curves and modeling tumor growth, both of which increase initially and then taper off.
Exponential Growth and Decay
Fits Exponential, Biexponential, Mechanistic Growth, Hybrid Exponential, and Cell Growth models. The Exponential 2P and 3P are similar, but the 3P model has an asymptote. The Biexponential models assume there are two separate growth or decay processes. The Mechanistic Growth and Exponential 3P models always increase (or decrease), but the rate of growth (or decay) slows so that the model has an asymptote. Examples of exponential growth and decay functions are virus spread and drug half-life, respectively.
Peak Models
Fits Gaussian Peak, ExGaussian Peak (Exponentially Modified Gaussian Peak), and Lorentzian Peak models. These models increase up to a peak and then decrease. The Gaussian Peak model is a scaled version of the Gaussian probability density function (PDF). The ExGaussian Peak model is similar to the Gaussian Peak model, but it can take on a skewed shape. The Lorentzian Peak model is a scaled version of the Cauchy distribution, a continuous probability distribution. These models can be used for some chemical concentration assays and artificial neural networks.
Pharmacokinetic Models
Fits the One Compartment Oral Dose model, the Two Compartment IV Bolus Dose model, and the Biexponential 4P model. This option is used to model the concentration of drugs in the body.
Rate Equations
Fits the Michaelis-Menten and Inverse Michaelis-Menten models, as well as several first order and second order rate models. The Michaelis-Menten model is a biochemical kinetics model, which relates the rate of enzymatic reactions to substrate concentration. The first order and second order rate models are useful in modeling chemical reactions.
Fit Antoine Equation
Fits the Antoine model, which is often used to model vapor pressure as a function of temperature. The Antoine model has both horizontal and vertical asymptotes.
Dissolution Curve Analysis
(Available only if both the response values and the regressor values are nonnegative.) Contains a submenu of options for dissolution curve analysis. A dissolution curve measures the rate at which a tablet dissolves over time. Dissolution curve analysis compares the dissolution curves of a new tablet to the dissolution curves of a standard or reference tablet. A separate analysis is done for each new tablet. The Dissolution Curve Analysis menu provides both parametric and nonparametric techniques for comparing dissolution curves. If you use one of the built-in dissolution curve models, a standard model fit report is created for each individual model that is fit.
Model-Free Comparisons
Provides nonparametric techniques to compare dissolution curves. If you use one of the nonparametric techniques from the Model-Free Comparisons submenu, a method specific dissolution curve report is created. See Model Comparison Report.
Note: All of the model-free comparison techniques require that the curves contain no missing values.
F1 Analysis
Performs an analysis using the F1 difference factor, which measures the percent difference between the curves of the reference tablet and the curves of the test tablet at each time point. See Statistical Details for Fit Curve Models. Confidence intervals for F1 are computed using a bootstrapping procedure. The bootstrapping procedure uses the bias-corrected and accelerated (BCa) percentile method. See Efron (1981).
When you select the F1 Analysis option, a Dissolution Curve Specification window appears. Use this window to specify the reference level, the alpha level used to calculate the confidence intervals, the number of bootstrap samples, and a random seed. If the data are in the Stacked Data Format, you must also specify the curve ID column, which identifies the individual curves within the reference group and the test groups.
F2 Analysis
Performs an analysis using the F2 similarity factor, which measures the similarity of percent dissolution between the curves of the reference tablet and the curves of the test tablet. See Statistical Details for Fit Curve Models. Confidence intervals for F2 are computed using a bootstrapping procedure. The bootstrapping procedure uses the bias-corrected and accelerated (BCa) percentile method. See Efron (1981). If the lower limit for F2 is greater than 50, then the conclusion is that the dissolution of the test tablet is similar to the dissolution of the reference tablet (Paixão et al. 2017).
When you select the F2 Analysis option, a Dissolution Curve Specification window appears. Use this window to specify the reference level, the alpha level used to calculate the confidence intervals, the number of bootstrap samples, and a random seed. If the data are in the Stacked Data Format, you must also specify the curve ID column, which identifies the individual curves within the reference group and the test groups.
Multivariate Distance
Performs an analysis using the Mahalanobis distance M, which measures the multivariate distance between the curves of the reference tablet and the curves of the test tablet. See Statistical Details for Fit Curve Models. Confidence intervals are calculated for M using a multivariate normal assumption. If the upper limit for M is less than the maximum difference, then the conclusion is that the dissolution of the test tablet is similar to the dissolution of the reference tablet (Paixão et al. 2017).
When you select the Multivariate Distance option, a Dissolution Curve Specification window appears. Use this window to specify the reference level and the alpha level used to calculate the confidence intervals. If the data are in the Stacked Data Format, you must also specify the curve ID column, which identifies the individual curves within the reference group and the test groups.
Higuchi Curves
Fits Higuchi models, including models with a time lag component and models with a burst component.
Hixson-Crowell Curves
Fits Hixson-Crowell models, including models with a time lag component.
Korsmeyer-Peppas Curves
Fits Korsmeyer-Peppas models, including models with a time lag component and models with a burst component.
Sigmoid Curves
Fits Logistic, Probit, and Weibull models. See Sigmoid Curves.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
